Morning all
Had a good weekend fitting D2 Coilovers and rear top camber link to my 97
R33GTR V all went very well.
The last job was to fit the Whiteline camber kit at the front.
As a lot of you will know the kit, for one corner, comprises of a steel sleeve with an eccentric M12 thread in each end, two M12 bolts 25mm and 50mm long, one lock nut, two washers and two bushes.
Could someone give me a clue on how this sleeve which measures 112mm long fits inside the upperwishbone which measures 102mm inner faces. Checked the part number of kit seems ok.
Was there a change in wishbone during R33 models ?
Also how do you turn this sleeve to adj camber once assembled ?
And what is the lock nut for?
Thanks for any clues...
