1 - 6 of 6 Posts
As per above, can anyone give me a guide to fitting the top half of the rear spoiler including swapping the brake light from the original.
Martyn
If I remember it correctly
remove bolts (each end)
remove brake light cover
unplug brake light where it exits spoiler
remove brake light with wiring
when installing back into new spoiler you will probably need to feed through a draw wire to pull the brake light cable back through to make life easy.
when removing my carbon one it took maybe 30 mins to do it.
remove the sticker circles x3 either end - gently heat to peel off
remove the posi screws then the plastic panel then the three ten mm's
the central mount is held down by both a pop clip and an adhesive pad which you will have to cut through with either fishing line or very carefully with a craft knife
then once separated on the drivers side of the car is the loom which has a plug under the foam wrap
locate and disconnect
you will now be able to take away from the car and remove all the screws under the sticker circles in the central panel plus the one in the base of the central mount
gently pry up the leading edge of the panel and slide forward and out from under the central mount
this exposes the last two screws at which point everything is separated
Ok I bit more involved than I though. Thanks for guide.
1 - 6 of 6 Posts
