1 - 12 of 12 Posts
Hi everyone,
My GTR suffers from a standard clanking noise. It's an my13 and it is the one identified in this blog post as #2.
Nissan GT-R (R35) Technical DIY Blog: Conducting the Symphony of Sounds from GT-R
Has anyone managed to find an effective way of addressing it? I'm hoping that since the blogger posted this a more effective fix has been found? Perhaps the my17 has yet another clip on the caliper that quietens the noise.
Frankly it's doing my head in.
Sent from my SM-G930F using Tapatalk
My first gtr (MY11) did this (rear pads bouncing in the caliper) but since then I've had a MY13 and a MY16 and neither have had rattling pads, so I thought they had cured it.
Have you got stock pads?
I don't have rattling pads, but I've got what I think is a tin rattle, must be a heat shield I think, so will have to get under at some point. Also noticed the fender trims were unstuck, so a bit of double sided tape for them too.
They have "character"!
Ohhhh... I think i have the same I'll be watching this thread.
Does yours sound almost like a pinking (old school) noise coming from the back? It only really happens when you put it under load but not quite on boost?
Kind of like low speed, high gear, then accelerate without a gear change to get it moving?
Nope. Cosworth street Master. Seem to be worse than the Pagid pads I was using before. I swapped them out because they sqeeled like hell. I've just swapped one annoying noise for another....
Discussion Starter #6
It's not the engine, it's the break pads. Sounds like a load of stuff rattling around in the boot but it's definitely the pads because as soon as I feather the brakes it vanishes until I let off.
I think it's towards the back, in the middle.
It only varies with wind and speed, so if I'm in a slip stream it stops, or low speed it reduces. It's completely unrelated to the engine or gearbox and I tried feathering the brakes with no affect. But yes, very pinky sounding!
That sounds like the rear amp/speaker between the rear seats, that resonates sometimes with low rpm. A thump on the side of it cures it for a few days.
Discussion Starter #10
I'm glad that everyone else's noises are being addressed except that of the OP....
Yeah I think i may have misled people with the pinking sound thing, i know its nothing to do with the engine, but pinking was the nearest sound i could describe it with.
It seems to come from the most extreme rear left of the car almost like an exhaust tip is rattling.
Also I only mention the engine under load thing as to get it to do the noise, I can get it at the exact resonant frequency that way. i think i might record it and post it up.
1 - 12 of 12 Posts
