I would like to ask all the owners of R34 if they have similar problem, I have installed a new battery in my R34 and after 1-2 weeks of not using the car the battery is getting flat, do you have the same problem???
The R34 is a UK spec and have a factory fitted combra alarm do you think that the alarm could be using all the battery till it gets flat or skylines have some electric device on that uses energy wile switched off ??
I have other cars with different alarms and can go for a month with out charge and still start.
Forgot to mention when the battery is out of energy the alarm is doing some noises probably to inform about the low batt.
