I have just fitted a a Bosch 044 fuel pump to my r33 GTR and now have a horrible flat spot at low revs, then the car suddenly takes off. Does anybody have an idea what could be causing this? I think it may be something to do with the variable voltage to the pump which I believe is standard on the GTR:confused:
i thought the voltage was only cut at idle too keep the pump noise down and prolong the life of the pump
There was no flat spot using the standard pump. The flat spot changes to full power occurs at about 4000 revs.:confused:
