We have RHD flex fuel kits in stock now
can be used on any spec gtr as long as has injectors, fuel pumps and mapped. engine/turbo can be any spec
E100 ethanol can be purchased in containers for much less than racefuel.
Change Cold Start Cranking Compensation based on ethanol content
Change Maximum Target Boost based on ethanol content.
Change Ignition timing based on ethanol content
Change target A/F based on ethanol content
Change Cam Timing based on ethanol content
Change Fuel Economy Gauge reading based on ethanol content.
'Plug & Play'.
The kit utilizes a Zeitronix Ethanol Content Analyzer and super slim GM Ethanol Content Sensor.
The Ethanol Content sensor mounts on the firewall and is connected to your fuel system by two stainless PTFE fuel lines.
The Fuel dampener easily accessible and attached to the back of your fuel rail by two 10mm bolts will need to be swapped out for the one that's included in this kit.
Everything plugs directly into the secondary air pump plug which is located next to the battery.
