1 - 6 of 6 Posts
Anyone know the location of the rear foglight fuse in a 2010 car please.
Fuse box.... Lol.... Is the yellow light on the dash lighting up when you activate the rear fog light, remember the full lights have to be on when you want to switch the rear fog light on. If the yellow rear fog light sign doesn't show then it's possibly a fuse, relay or stalk. The gtr has three fuse boxes, look in the hand book it'll show you diagram if the fuse boxes
Yeah the handbook does not say which fuse box !!!! The orange light is coming on but no power to the plug that the bulb sits in.
If you have a 12v light probe, then put the lights on and the rear fog light on and check each fuse both sides and the fuse which only lights up your tester on one side is your culprit. You have one big fuse box out side near the battery section and two fuse boxes inside one on each side kick panels
I was hoping to not do the probe thin LOL theres 2 fuse boxes in the battery dept so that makes 4, well im pretty sure its not in the driver kick panel so 3 !!!
Stop being lazy.... Lol just go check them
1 - 6 of 6 Posts
