I thought id make a thread dedicated soley to the engines I have for sale.
both removed from my own cars
first engine is the 655hub hp, 493 hub lbft rb26
this power was made February this year and motor has done approx. 1 - 2k miles since
mileage is unknown but ive removed the sump for inspection and can confirm
hks rods and pistons 87mm bore so 2650 cc
jun oil pump
trust sump extension and baffle/pick up
stock crank lightened and balanced
standard diff in sump
hks 1.6mm headgasket
tomei headstuds
hks cambelt and idler/tensioner 2k miles
os giken cam gears
apexi stage 2 cams 10.3mm lift, 260 d duration
ported head inlet and exhaust
oil pressure 40 psi idle, 82 psi 4k rpm +
I made sure to get pics of oil pressure before I stripped the cars
it has been super reliable I clocked 0 - 100 in 7.2 seconds, and 30 - 130 in 9.76 seconds results are on the forum in skyline chat vbox runs
we all know how much ££££ it would cost to replicate this engine, priced to sell at £4000 which imo is a bargain price
second motor has done just 2.4k miles since complete rebuild !
motor was rebuilt by broadspeed services and I have receipts for work done.
spec of motor
87mm je forged pistons with oversized gudgeon pins
new little end bearings resized for oversize gudgeon pin
acl race big end and main bearings
all new gaskets and seals throughout
new water pump
oil pump stripped, inspected and rebuilt
new cambelt
cylinder block bored and decked
crankshaft checked for straightness and journals polished
motor was ran in for 1k miles at 0.5 bar. then ran 1.2 bar for 1.4k miles and that is it. excellent oil pressure as pictured below
priced at £3500 due to being almost new and forged pistons
jun oil pump
tomei headstuds
os giken cam gears
spec of motor
new water pump
new cambelt
