1 - 19 of 19 Posts
Hi :wavey:
I'm French and I have since the month of April 2009 achieved my dream thanks to harlow jap autos ;)
Years: 1996
Kilometer: 43Kmiles
Kilometer engine: 7Kmiles
Turbo pressure: 1,1 bar -> 400-450Hp
ENGINE
BNR 34 ( 24U ) N1 engine (N1 piston/Oil pump/water pump)
BNR34 sauge tank
BNR34 ball bearing turbine
HKS combination metal gasket
NISMO low temp thermostat
TRUST OIL filler cap
Irridium spark plugs
INTAKE · EXHAUST SYSTEM
HKS special piping KIT
TRUST triple core intercooler
HKS intercooler pipe
FUJITSUBO SUS front pipe
APEX N1 full titan muffler
COOLING SYSTEM
KOYO All aluminum triple core radiator
TRUST relocation oil filter
TRUST oil radiator
BILLION silicon radiator hose SET
ARC Titan radiator hood panel
DRIVETRAIN
NISMO G-MAX twin plate clutch
NISMO Stainless mesh clutch line
CRUX Suspension KIT( 30levels adjustable )
SWIFT F 12kg/cm-7in R10kg/cm-8in
NISMO circuit link SET
HKS KANSAI front tower brace
NISMO bush · member · changed stronger
Spot welded chassis (for rigidity)
BRAKE SYSTEM
LOCKHEED both side 6 slit brake router
PRO-MU reinforced brake pad B/F
APP stainless mesh brake line
INTERIOR SYSTEM
SAFETY 21 8points roll gauge
NISMO shift knob
NISMO white 320KM full scale meter ( changed at 45,400KM )
NISMO white triple meter
NISMO sports pedal SET
Defi link meter ( water temp · oil temp · boost )
HKS turbo timer
HKS boost controller
ALPINE CDA-9855J audio
ALPINE tweeter
Deep corn steering wheel
Carbon shift · meter console panel
EXTERIOR
Gram lights 57F PRO 18inch AW
Potenza RE01R 265-35-18
Zenky racing black Lugnuts
Late model large stock lip spoiler
East Bear clear winker
Nismo clear lend side winker
Knight racer carbon blade
Nismo rear spoiler carbon garnish plate
:chairshot
Bienvenue à toi sur le forum Bisounours :)
N'hésite pas à passer dans la section française du forum et si tu as des questions n'hésite pas à me PM
1 - 19 of 19 Posts
