1 way? 2 way? Mech LSD? Vis LSD?
1 .....Has anyone replaced the std open diff in the front with a real diff?
2 ....Better for the track? Turn in? Drive out?
I'm still in the process of putting the 4:375 GTS4 ratios in, and thought at the same time....Diff change?
I doubt it is a very common upgrade due to the heavy rear drive bias, and the understeer nature of the car.
For sure a 2 way would make the handling even worse, as it would induce more understeer. I would imagine the only LSD you could use that wouldn't screw up the turn in is a Torsen type.
1 or 1.5 way would be the go up front. Cusco & Quaiffe come recommended.
I've been told that a change in driving style to suit is required, but the rewards are there for the taking :)
SAU has more info if it dries up here.
Owner of the MSNSPS
If it's any help the Quaiffe ATB units are Torsen by another name (Automatic Torque Biasing or some such).
I remember people with GTIRs fitting them and finding that they reduced understeer. However that's a permanent 4WD system...
Garage Bomber has a 1.5 fitted, came with it. Give away is the clunking on full lock and/or when I have the HKS ETC running permanent 4WD.
Is it any good? Don't know as it has always had it! Certianly goes where I point it though (usually).
DaveG
