It's finally time to change the front brake discs on my R33 V-Spec.
So should I just stick with the Original equipment discs or is there something better out there???
Also roughly how much are the standard discs???
Try ringing Middlehursts:D
Then you will buy aftermarket.
I am happy with std R34 setup on My R32 at the mo but would have AP setup if I could afford it. £1500?
Nearly new secondhand would be your best bet for OE setup as a lot of people upgrade to aftermarket and sell good condition discs.
APEXi Front Discs
Try speaking to Kiki at Option Motorsport, a set of the above disc are not too costly and they look the business, anodised bell housing etc.
Set of these with some quality pads should do the trick, unless you are using the car for heavy track use.
Regards
