1 - 9 of 9 Posts
Hey guys,
I have a MY15 and I want to change out the orange light bulbs that are in the headlight. What bulbs would I need to buy and how easy is this to do?
Thanks guys.
Original bulb is WY21W so find a replacement of that type and that has built in resistance otherwise they***8217;ll flash too fast.
Access iirc can be done from the front wheel arches with the liners partially removed.
Original bulb is WY21W so find a replacement of that type and that has built in resistance otherwise they’ll flash too fast.
Is that for the one on the side or the one in the headlight?
Er you asked about the headlight... :eek:
Access isn’t easy in my opinion, as above, remove the arch lining and wheel. Maybe the bumper if you need the headlight out.
Why do you want to change the bulb? Side lights are very simple.
194 wedge type I believe arenfor the side markers
Discussion Starter #8
Not to keen on the orange bulb in the headlight.
1 - 9 of 9 Posts
