1 - 20 of 25 Posts
hi all,
had an inspection carried out on my car, and the mechanic pointed out the bushes on the front lower wishbones, are very worn. The ones at the back.
However, according to his purchase system, you can only buy the complete arms @ £549.99 each ! and I need two, plus labour..
which seems ridiculous.
my question is - does anyone sell these bushes separately, or are there any after market ones available ?
thanks
Nick
Hi Nick
The rear bushes crack and squeeking is an early sign of them going. You have to buy brand new arms or Litchfields sell there version of the bush which alters the geometry for a supposed better drive.
I have a set of used ones and I think a solo drivers side.
Hi Nick
Hi,
I don't have any "sqeeking" as such.. just a slight knock under the car, under the drivers side wheel it seems, when going over bumps..
funny thing is, only happens when it is cold. after a couple of miles it disappears. as if the bush somehow expands... but pretty sure none of them are oil filled.
if you have a drivers side you want too sell.. I would be keen depending on price of course :)
the b5 A4 used to do creak and knock over bumps when the lower bushes failed as well. The only solution for that was complete new arms.
Discussion Starter #7
i am not sure its that....
there is no creeking or noise like that. the "knock" feels like its under my feet, and disappears after about a mile or so of driving..
Yeah, the listing title implies its for both but then says you only get one in the main ad :confused: Looks like another expensive part to buy if you can't get just the bushing itself
Nissan part numbers for lower wishbone (complete) are:
Up to 2011 (CBA)
54500-JF50A Right Hand side
54501-JF50A Left Hand side
2011 onwards
54500-38B0A Right Hand side
54501-38B0A Left Hand side
Really common issue to have the rear bushes fail. Changing to aftermarket ones is a massive improvement in not only the geometry when taking advantage of the extra caster addition/anti dive but also in the fact the wheels won't tramp for and back in the arch under hard braking.
We use the Superpro ones, massively superior material for such an application (and being able to bond it to metal means you can use an offset bush instead of having to remanufacture the whole mount. They are £187 plus vat.
https://www.superproeurope.com/part.number.cfm?partnumber=SPF3852K
1 - 20 of 25 Posts
