NEW never used. The wires havent even been unwrapped. No box but factory instruction manual is included.
Would like $200 for it (approx 106 GBP)
As per MSD website:
Adding a turbo or supercharger to your engine is a great way to improve the power of your car. But you have to remember that when more air is being pushed into the engine, the need for additional fuel raises proportionally. Meeting these new fuel demands could mean larger injectors or ECU programming, both which can be pricey. This new Fuel Pump Booster is the economical (and easy) answer for your engine’s new fuel demands.
The Booster will supply the electric fuel pump with increased voltage in relation to the manifold boost pressure. As boost pressure increases in the manifold, the MSD Booster will increase the voltage to the electric fuel pump. The amount of voltage is adjustable with a potentiometer from a range of an additional 1.5 volts to a maximum output of 22 volts over a range of 5 – 30 psia.
Please read the quoute. This is NOT a relay to give full voltage to the fuel pump. This reads your boost pressure and ups the voltage to the pump as per user selection. Very cool part.
Will trade for Nismo bits or gauges. Thanks!
Discussion Starter · #2 · (Edited)
Offers? TTT
SOLD
