Simple question.. if i want to increase fuel pressure slightly do i screw in the adjustable screw or release it. I would guess at screw it in a bit more but hey when you dont know you dont know!!
Chaz
Usually in but you should have a guage on there anyway so you can check your pressure as you make adjustments.
Rob
Cheers rob, I will get a pressure guage on there too so i know whats happening. Am only tweaking it slightly to help with hot starting.. my apexi pfc map and major settings are locked out
