1 - 7 of 7 Posts
Hi,
I plan to install a Bosch 044 in my R32 GTR but i'd like to know which are the inlet/outlet sizes i need.
Thanks, Franklin.
bosch 0 580 254 044
flow qty. - 200-300lph
pressure - 5bar
inlet - M18 x1.5
outlet - M12 x 1.5
length - 196mm
diameter - 60mm
max power - 15.5AMP
ground/12V - M5/M6
Discussion Starter #4
I also would like to know if this can be installed prior to other upgrades (injectors, bigger turbo's...) without a remap.
Discussion Starter #6
I saw on a seller website i can choose the "AN" fittings. Which are the right ones for my BNR32?
AN just referes to the size of hose you can run off them.
-8 or -10 is common for the inlet to the pump and -6 is common to run to the rail (aprox 8mm ID)
Rob
1 - 7 of 7 Posts
