1 - 6 of 6 Posts
quick question guys please... does it need a remap if replacing a fuel pump? afaik im running hks fuel pump but changing to bosch 044 (if this is the correct one equivalent to the hks?).
thanks
Skyline Section Manager
As long as the fuel pressure is the same and the injectors are the same then a remap would not be required.
@andy
same injectors yes. im still running the oem fuel regulator and rail so i take it the same? thanks bud
@johnnypolish
im running in-tank so thank you about 040. i pressume they have the same capacity? thanks
1 - 6 of 6 Posts
