Hi
Just been shopping, bought a Bosche 044 pump and a stack of Aeroquip line and fittings......
Can anyone point me in the direction of a schematic drawing of the standard R33 GTR fuel system and a further schematic of an upgraded system ie using the Bosche pump, which regulator, filter ect..
Many thanks
mate i have just fitted a bosch 044 pump i mounted it in tank with a strainer/sock on the bottom there are instructions how to at this site
Bosch 044 Intank R32 Gtr - Skylines Australia
as for pressure regulator im using standard, no need to change, after fitting i tested pressure and flow at over my maximum boost pressure by presurising the fuel pressure reg and it flowed 2.9 lpm at 70 psi rail pressure.
one thing with the instructions my tuner said to remove the small over pressure valve mounted just above the std pump.
oh and i used teflon lined braided stainless steel hose instead of rubber on the outlet of the pump as some people have issues with rubber hose as most are not fuel resistant on the outside.
good luck its easy realy
Many thanks......... I'm printing the link off now. All the hose i'm using is teflon lined stainless -6. Any idea what power a single 044 is good for before the need for twin pumps ?
Thanks again Bryan
