Hi guys i want to fit a Bosch 044 pump in line (without surge tank) under my car im not to sure which line is the fuel line under the car? The standard pump will remain in the tank. I know I could possibly follow it from the engine as you cant see where the fuel line go on the standard pump. So has anyone got any pictures or diagrams showing where I could fit the 044 pump and which fuel line do connect to?
I wanted to get some advice first before I start cutting into fuel lines.
What Iv done so far (for other user searching the forum)
The wiring has already been put into place.
Signal taken from the OEM pump
White wire positive, only powers up when there is a pressure drop on the fuel rail (create a leak for testing)
fuel pump location
smaller connector is the power
larger connector fuel gauge
Pump with all fitting.
does it matter if I use connection A or B? A has a spring and a small ball bearing within it cant remember what its call or it advantages or just connection B?
sorry for all the question iv searched but cant find a “direct” answers, I appreciate your comments.:thumbsup:
fuel pump location
