My Full-Race goodies are trickling in! The quality and craftsmanship is the best, I work as a level A welder and inspector in Canada and I can appreciate top notch work!
I'm going to be selling my 90mm Arc Ti cat back so I can swap in......
-100mm OD .9mm wall thickness 321 stainless down pipe
-100mm OD 1mm wall thickness grade 3 ti for exhaust
-100mm ID x 300mm burns stainless muffler
-100mm OD .9mm wall thickness grade 3 ti for intake pipe routed into bumper
-75mm grade 2 ti for the two charge pipes in the engine bay
I'll be doing the welding since I can
The head is getting 280 11.35 cams, better springs, cam gears and a port match and polish.
Example of Borg Warner S300sx 83/75
Main: Nissan Forums / Infiniti Forums - NICOclub
Here are the others parts as well most of them on the car or in my back stock
Engine
-new factory RBDETT 2.6
-Full-Race maniflod
-Borg warner s300sx 83/75
-tial wastegates
-twin screamer pipes
-Arc 100mm intercooler
-Apexi Power Fc ecu
-Z32 mafs
-Datalogit software
-Blitz SBC-id3
-NGK 9's
-Apexi fuel pump
-1000 cc RC injectors
-Sard fuel rail with -6 in and -8 out
-Nismo single plate clutch...to be upgraded
-Nismo engine mounts
-Aluminum intake pipes.....ditching
-HKS Kansai torque controller
-HKS bov's
-K&N comes
-Garage defend carbon cooling panel
-Earls oil cooler & oil filter relocation
-Samco hoses
-Splitfire coils
-Cusco brake stopper
-Koyo rad 53mm core
-Flexite electric fan
-Trust downpipe.....selling
-Arc Ti 100mm cat back...selling
-stainless de-cat....selling
Exterior
-2005 Acura Tsx hid system (projectors and ballasts) 4100K
-N1 vents
-Factory Nissan mud guards and rear aprons
-Nismo hood spoiler
-Garage Saurus drag wing
-18" x 10" 16mm offset SSR SP1 professor...street wheels
-Yokohama A048's 285/30/18
-OEM drilled rotors
-project Mu pads front
-Hawk HP+ rear
Suspension
-Nismo front strut bar
-Buddy Club Junior Spec coilovers
spring rates 12kg/front 10kg/rear
-Cusco rear strut bar
-Cusco tension rods
-Cusco tension rod bar
-AMS adjustable rear upper link
-adjustable front upper links
-Tomei hicas lock
Interior
-Nismo gauge cluster
-Greddy EGT,oil pressure,fuel pressure and oil temperature
-Innovate Lc-1 wideband and G3 gauge
-Momo 330mm suede steering wheel
-Momo GTR gear knob
285/30/18 AO48 with Arc Ti in the background
Stayed tuned for the install and dyno graphs
Engine
-Full-Race maniflod
-tial wastegates
-Apexi Power Fc ecu
-Z32 mafs
-Datalogit software
-Blitz SBC-id3
-NGK 9's
-Apexi fuel pump
-HKS bov's
-K&N comes
-Samco hoses
-Splitfire coils
-Koyo rad 53mm core
Exterior
-N1 vents
-Nismo hood spoiler
-OEM drilled rotors
-Hawk HP+ rear
Suspension
-Cusco tension rods
-Tomei hicas lock
Interior
-Momo GTR gear knob
