No, the Grid Dancer controls the electronic solenoid on its own, completely removing any input from the ATTESA system. The unit has a dummy coil (8ohms) to fools the ATTESA into thinking there is still a solenoid attached thus not throwing up a fault code and shutting down. The dash control for the Grid Dancer controls the electronic solenoids offering a driver variable torque split.Grid dancer doesn't eliminate the G-Sensor, it's just a controller that adjusts the output value of the G-Sensor to give more 4WD.
Sorry, my fault. Was always under the impression that this one works too with the srock g-sensor :nervous:No, the Grid Dancer controls the electronic solenoid on its own, completely removing any input from the ATTESA system. The unit has a dummy coil (8ohms) to fools the ATTESA into thinking there is still a solenoid attached thus not throwing up a fault code and shutting down. The dash control for the Grid Dancer controls the electronic solenoids offering a driver variable torque split.
I hope this clears things up.
