Garage Whifbitz stage 1 730bhp turbos for the Nissan R35 GTR. These turbos are capable of giving your Nissan R35 GTR 730bhp with the correct supporting mods, we sell our stage 6 power upgrade kit which you can see on our website under the power uprade section, this comes with everything you need.
The turbos are modified to produce the extra power with a new larger 60mm IHI compressor wheel along with a 360 degree thrust motorsport bearing. These allow the turbos to give more power with only a small loss in turbo lag, the difference between 650bhp and 730bhp is very noticeable, allowing the power to keep going all the way to the redline. These maintain the use of all the standard oil & water lines, mounting points making them a direct swap for the standard units.
C.N.C Machined Compressor Cover
60mm IHI Compressor Wheel
Modified Diffuser
360 Degree Divided Thrust Motorsport Thrust Bearing
Modified Turbine Wheel
The turbos are sold on an exchange basis so will need your old units, a surcharge is payable which will be refunded when your old units have been received and checked over.
Prices are shown on our website here Turbo Upgrades & Parts - GTR - NISSAN - Garage Whifbitz
Paul
Modified Diffuser
Paul
