1 - 8 of 8 Posts
Has anyone got any spare inlet manifold and turbo outlet pipe gaskets for an R33 GTR.. also a couple of cam cover gaskets.
If not can anyone recommend where to get them please?
Thank you
Lee
Inlet gaskets are available from Sumo Power for HKS items. IIRC £5-6 for the throttle body ones, and £9.50 or so for the main long one.
Rocker cover gaskets are available from your local dealer. Part numbers below. These are for R34 GTR, but sure they should be the same.
Qty 1 Rocker cover gasket 13270-58S01
Qty 1 Rocker cover gasket (2) 13270-58S11
Qty 2 Rocker cover gasket "D" 11051-58S00
Yes they are very cheap. The whole set is under £30 IIRC
Great.. bargain!
Is the third rocker cover gaset you listed as qty 2 the rubber bungs?? or just a two pack? do the rubber bungs need replacement as well?
Thank you again..
Roll on polish and paint!
Lee
They are shaped like a "D" and sit right at the back of the rocker cover. In the middle.
You'll see what i mean when you see them. These are very cheap and yes you need 2. They don't come in a set or pack. So make sure you order 2.
Mine were next day, so shouldn't be an issue to get them
1 - 8 of 8 Posts
