Hi guys... Just wondering has anyone out there that had done there's and managed to tate any photos of the fluid change... Thanks for any help.
Andy
Andy
No photos but its pretty straightforward. Gearbox has a fill bung on the O/S of the gearbox that has a square drive. Same as the drain bung on the bottom of the box. I would always undo the fill bung before the drain bung in case you run into any issues! Once the old oil is drained and the plug tight fill with oil until it starts to come out of the fill bung as this acts as a level.
Same procedure for the diffs. You will find the fill plug for the rear diff on the back housing and for the front diff on the front cover.
Will be a messy job without a ramp. The bungs can be very tight as well.
