1 - 9 of 9 Posts
I've just finished applying sealing the gearbox tunnel with epoxy mastic and then stone chip ontop. What is best to use to stop the gearbox/engine heat coming inside?
Anyone made any aluminium shields? Or just using the tape?
Post some pics up please, does the tape work well?
I'm thinking of using a single sheet of aluminium and shape it to the tunnel, then anodise it?
We use it on the bulkhead, the rear diffuser and on the wishbones on my FR, infact all the teams use it as it is very good at heat management. Can also supply it if your interested. can do 12"x12" or 24"x24" sheets
Following EJH#25
I ordered the 48" sheet and half of it did the transmission tunnel.
Next time the engine is out, the plan is to do the fire wall / bulkhead.
1 - 9 of 9 Posts
