Guys,
Not sure how much of an issue this actually is as it has only happened twice but thought i would check to see if it has happened to anyone else?
I came of the Motorway today in 5th gear went to downshift and the gearstick wouldnt release from 5th. So i brought the clutch back up and down again and this time it released
Anyway i got home parked up, when i got back in the car about 10 mins later i tried to reverse out but couldnt select reverse. I tried everything putting it into all gears, moving forward, turning the car on and off, clutch in and out but nothing could select reverse. I had to end up pushing the car out of the drive and then moving forward. After 10 mins of driving i managed to hit some traffic and kept fiddling with it and it finally engaged reverse.
This has happened once before so not sure if its an issue i should be worried about? Any thoughts or ideas?
Car is a R32 GTR - pretty standard with minimal mods.
V
V
