Cheers Guys.
The car already has quite an extensive spec list to go with a 1000hp build but I need to add a few touches.
The 2009 box had 'expiered' so a 2012 model (with only around 4k miles on it) was sourced by the 'Crew that Do' that was then beefed up with............
Albins 1-6 gearset & all the relevant clips etc.
Then it needs some stopping power as it'll be getting tracked...........
Alcon Big Brake setup
Then a set of Eibach ARB's front & back were added to complement their lowering Springs.
Also a tracker was fitted whilst at SVM.
A few other touches will be done to personalise it a little further as time goes by :smokin:
As mentioned earlier Kev & the boys really have pulled out the stops to get it ready in plenty of time for the Euro Tour. Thanks :bowdown1:
Engine Specifications:
Full SRD Dynamically Balanced engine build.
Manley 'platinum series' Pistons
Carrillo H-Beam Rods
Compression raised 10:1
SRD Ported Heads
Titan 274 degree 10.55 lift Cams
Supertech Valve Spring Kit
Full EGR removal
Turbocharger & Induction:
Whifbitz GTR turbokit
Heat wrapped custom headers & down pipes
GTX 3071r billet turbos with upgraded metal bearings (53mm)
Turbosmart hypergate45 wastegates
Whifbitz 3" Downpipes
SRD 89mm Intake Kit
HKS plenum
HKS 12 injector kit
SVM 70mm billet Throttle bodies.
Turbosmart BOV's
DEI Titanium Turbo blankets
Fuel, Tuning & ECU:
Syvecs S8 PNP ECU mapped by 2Bartuning
Switchable Syvecs 4WD/RWD controller
Syvecs 12 injector loom
Syvecs I/O expander
Syvecs Fuel Flex Sensor
Syvevs Bluetooth module
Toucan Touch Screen Display.
Fuelab Fuel Pressure regulator
12 x injectors, 6 x OEM 570cc and 6 x ASNU 1100cc injectors
-10 Teflon fuel lines
AMS fuel pump kit 2x Bosch 044
SRD billet fuel tank hat
AMS 4 Bar Map Sensor
Aeromotive fuel pump voltage controller
Exhaust:
SVM 102mm exhaust
SRD switchable exhaust valve (silencer bypass)
Boostlogic F16 Tips
Cooling:
HKS DCT gearbox cooler
HKS rear differential cooler
Forge Motorsport Black Alloy Header Tank
Forge Hose Kit
SRD FMIC and 76mm hard pipe kit
SRD Fuel cooler
Murray Clamps
Drivetrain:
HKS Gearbox Sump
Willall diff brace
Albins 1st gear upgrade
SVM 3x circlips
SVM 14 plate clutch
SVM strengthened gears
Dodson Magnet upgrade
Suspension, Wheels, Tires & Brakes:
Volk VR G2 20" wheels
Front 10x20 +35
Rear 11x20 +15
MPSS in 335 & 285mm
Alcon front and rear discs
Eibach lowering Springs
Exterior:
KnightRacer CD Carbon Wing
Zele Carbon Side Skirts
Knightracer/Mines Type II Carbon Front Splitter
Carbon Fender Vents
Carbon Front Fender Logo Garnish
Carbon bumber Grill
GTC 4 tail light kit
Interior
Mines Steering wheel.
Carbon trim
