1 - 13 of 13 Posts
Thing is I don't know anything about my head
only thing I know is it has step two cams !
Now I will be taking my engine out for two reasons
1. My starter motor has gone
2. Got oil leak coming from sump and sump bolt is spin loose on rread
While its out I want to polish and port the head but I don't know much about head work so,
how would you guys build a head for a 2.8 with 2530 tubbys
unless your experienced in doing headwork, i would send it to a machine shop who nows what they are doing,otherwise you can end up making a right mess of your head.
All depends on how much you want to spend if money is no object I would do this
Amt full port job
Oversized valves
Amt valve seat job
Amt custom cams
Bronze valve guides
Double valve springs
Titanium retainers
If money is a object and your looking for bang for buck
Full port job
Amt custom cams
Bronze valve guides
Dan
Discussion Starter #4
Sorry Simon dint say the head will be be going abbey as Im think of a VCAM but then MGT build the engine on it before I bought so it would be best if they do plus they have got a lot of positive feed back on here
Completely agree unless you have a flow bench it's really hard to no if what your doing is the right or wrong way to go it's not a simple as pulling a air grinder out
What vcam you going for? Would be interesting to see say a step 1 vcam kit what costs over 2k tested against some right fancy high lift cams
Discussion Starter #7
Amt full port job
Oversized valves
Amt valve seat job
Amt custom cams
Bronze valve guides
Titanium retainers
Full port job
Amt custom cams
Bronze valve guides
Dan
I am not doing the work on the head it'll will be professionally done !
Not by AMT mgt or Abbey will !!
I just like to hear hear everyone's own view
:thumbsup:
:thumbsup:
I was just giving you what I would call my best spec head mate,
What machine shop do you use for your head work or who will you be using do you no yet?
Dan
There's always CNCHeads...
Their offerings always look pretty decent although no idea of flow numbers etc..
TT
I would highly recommend Dave Andrews very good workmanship and he has vast experience in porting work. He did a couple of heads for me in the past.
Dave Andrews of DVA in MK??
Was it RB heads he did for you?
TT
1 - 13 of 13 Posts
