Hi,
Just want to know what are the differences between the 2 versions, i don't want to waste money if this is not neccesary.
This would go in a R32 GTR with N1 turbo's, apexi induction kit,full exhaust system with decat.
Thanks, Franklin.
Gizzmo Electronics website lists the differences... ;)
MSIBC has 6 scramble boost settings and closed-loop boost control (I think the IBC doesn't). I wouldn't bother though, had a MSIBC and never really worked for me.
I did research too before buying it but the reality is that it didn't perform as well as other EBC's I've tried.
Example, I would set it at 1.20bar: It will reach 1.20 then fluctuate between 1.15 to 1.25 until 6000rpm then drop off (this is quite normal). The fluctuation wasn't normal. No boost leaks, triple-verified everything and tested every possible setting. Best results were at very low gain (between 0 and 8) and played with the spike stop setting as well but I wasn't particularly impressed.
I now have a Blitz i-Color SBC Spec R which is excellent, but much more expensive.
