Gold Detailing Package
"The Enhancement package"
For a deep clean and a deep gloss shine!
Following the same processes from our Silver package, we seal your paintwork using a Dodojuice high Carnauba content wax or Dodo Juice Supernatural high Carnauba content hybrid wax (sealant and wax combined). Carnauba wax gives your car an unbelievable deep gloss finish which if maintained properly can last for up to a year if your vehicle is maintained properly.* There are many wax options to choose from, and we are always adding to our range constantly. If you are unsure what wax is best for you, we will advise you on which wax option is best suited for your vehicle.
[We may require your vehicle for up to a maximum of 24 hours, but only in extreme circumstances.]
*(if used in conjunction with our bronze package at the recommended intervals. Not including extreme weather circumstances or extreme vehicle use.)
Cost: £100
£20 Extra for plus size vehicles.
Examples:
Vans: Ford Transit, VW Transporter, Mercedes Sprinter ect
Pickups: Nissan Navara, Toyota Hilux, Dodge Ram ect
4x4: Range Rover, Discovery, Mitsubishi Shogun ect
Vehicle rinsed using low pressure filtered water
Lower third sprayed with a non caustic citrus cleaner, and rinsed
Wheels, arches and door shuts cleaned by hand with a non caustic citrus degreaser
Wheels cleaned with a pH neutral wheel cleaner
Vehicle sprayed with a pH neutral snow foam, left to dwell and rinsed
Hand washed using a sheep wool mitt, with a pH neutral shampoo using 2 bucket method
Tar removed from vehicle
Hand dried using high quality, specialist, microfibre drying towels
Clay bar/clay sponge paintwork and glass to remove any contamination
Dodojuice high Carnauba content wax or Dodojuice Supernatural hybrid wax applied to paintwork, and door shuts
Chrome/stainless steel polished including exhaust tips
Interior glass cleaned
Exterior windows and mirrors cleaned
Layer of detailing spray applied
Tyres cleaned and tyre dressing applied (satin finish)
Final inspection to make sure your car meets our high standards
