Administrator
If you have a 4.0L fuel injected Jeep from 1991-2006, you can simply purchase one of our complete Jeep crate engines. Auxiliaries will be a straight swap from your stock 4.0L engine onto the new 4.6L stroker. There's no tuning needed on 1991-2006 year models; your stock computer will run the engine without a problem.
MACHINED, BALANCED & BLUPRINTED
4.6L 270 HP Jeep Complete Engine
VIEW ENGINE SPECS
JEEP 4.6L 270 HP COMPLETE ENGINE DYNO
Questions? Give us a call at 1-866-550-3116 or Contact Us and we’ll get in touch with you right away.
Pricing on 4.6L Jeep Complete Engine for 1991-2006 fuel injected Jeeps:
Complete Engine Includes the following parts and services:
  • Dyno Break In Service
  • Oil pan
  • Timing cover
  • Slinger and Buffer for timing cover
  • Oil pan and timing cover bolt kit
  • Valve Cover Kit w/ Golen 4.6L Badge
  • Harmonic balancer pulley
  • Labor to install covers
  • Joe Gibbs 15w50 Break In Oil
  • Oil filters (3)
  • Spark plugs
  • 24lb Fuel Injector Kit
Optional Parts to gain a little more power:
  • Performance tubular stainless steel header $425
  • 62mm Throttle Body 1991-2004 $295
  • Flow Kooler - High Flow Water Pump $125
1971-1990 4.2L CARBURETED JEEPS
Our turnkey 4.6L Stroker Engine comes in both EFI and Carbureted options and is a direct replacement for your stock 4.2L engine. Each engine comes dyno tested and tuned so it's ready to run when you receive it, and comes with a 3 year no mileage limit warranty.
4.6L 270 HP JEEP EFI TURN KEY
JEEP 4.6L 270 HP EFI TURNKEY ENGINE
VIEW ENGINE SPECS
JEEP 4.6L 270 HP EFI TURNKEY ENGINE DYNO
Pricing on 4.6L Jeep EFI Turnkey for 1971-1990 Jeeps:
Parts and Services Included in Jeep EFI Turnkey Engine:
  • Dyno Break-In and Tuning Service
  • Oil pan
  • Timing cover
  • Valve Cover Breathers with PCV
  • Joe Gibbs 10w40 Break In Oil
  • Oil filters (3)
  • Spark plugs
  • Performance intake manifold
  • Holley Sniper EFI Master Kit with Fuel Pump
  • Holley Sniper EFI Ignition
  • Performance Spark Plug Wires
  • Flowkooler High Flow Water Pump
  • Thermostat Housing and Thermostat
4.6L 270 HP JEEP CARB TURN KEY
JEEP 4.6L 270 HP CARB TURNKEY ENGINE
VIEW ENGINE SPECS
JEEP 4.6L 270 HP CARB TURNKEY ENGINE DYNO
Pricing on 4.6L Jeep Carb Turnkey for 1971-1990 Jeeps:
Parts and Services Included in Jeep Carb Turnkey Engine:
  • Oil pan
  • Timing cover
  • Oil filters (3)
  • Spark plugs
  • Holley 390cfm Carb w/electric choke
  • HEI Distributor and Coil Kit
DYNO BREAK IN SERVICE
We offer an extensive dyno break in service for our Jeep 4.6 stroker engine to ensure that it is running properly before you install it into your Jeep. Using our two brand new Superflow SF-902 Dynamometers we will run your engine for a complete break in cycle monitoring all engine vitals over the course of a few hours. Once the break in cycle is complete, we will change the oil, inspect the oil filter and re-torque all fasteners. At this point, we will run the engine between 10-15 full rpm pulls while recording all engine vitals and looking for consistent power readings from run to run. We will provide you with a video of your engine running on the dyno and accompany it with copies of the dyno readings for your records. Customers are always welcome to visit our shop and see their Jeep engines run on the dyno and take them home the same day, this service is by appointment only.
JEEP 4.6L 270 HP BARE LONG BLOCK ENGINE
4.6L 270 HP JEEP BARE LONG BLOCK
Pricing on Bare 4.6L Jeep long block for 1991-2006 fuel injected Jeeps:
  • 1991-1999 year models $4699
  • 2000-2006 year models $5049
Included with Long Block:
  • All gaskets to finish install
  • Oil pump and Pick Up Screen
Required parts to properly run fuel injected engines 1991-2006:
  • 24lb fuel injector kit $375
  • Joe Gibbs 15w50 Break In Oil $95
