Hey Andy,
Think it's brilliant you've started this kind of thread so thank you.
I had a question. Are there any products you recommend for detailing gloss black interior plastics? For example in my R32 the window/mirror control panel on the driver door has faint swirl marks and I wasnt sure what products would be effective and safe on that kind of material.
Any advice would be appreciated.
Jai
Hi Jai, thanks for commenting!
Interior detailing can be a tricky one to DIY, but the best bet would be to try out something very mild and work up from there, start with something like the Auto Finesse polishes by hand - Tripple or Rejuvenate - something that wouldn't usually correct paint can very easily correct plastic.
Ideally remove the trim from the car where possible, as most polishes will stain or damage leather, plastic and trim.
Interior gloss black can be VERY soft, so be careful, something too abrasive can cause micro-scratches and haze, which would be hard to remove without machine polishing!
Hope that helps, drop me a message if you get stuck! :thumbsup:
