Hi,
We have a batch of these due in and have a special on them for this batch.
Price - £359 Delivered
For more information or to order please click here
Some Info
As easy to use as a manual boost controller, but with advanced electronic boost controller response & consistency, the Profec OLED keeps things simple. Based on the ever-popular Original Profec series, the Profec OLED is very easy to use with 2 buttons and a rotating dial with push button function.
Greddy adopted a display (EL organic) OLED with excellent visibility. By brighter than conventional LCD, OLED maximizes the clear display with a wide viewing angle you have exhibit excellent visibility even with the compact screen size.
***8251; OLED: Organic Light-Emitting Diode
The OLED map sensor can take a pressure until 300kPa (3.0bar)
Simple to set as a manual boost control and features electronic response
A new compact, high capacity solenoid valve is introduced with the Profec OLED. It also improves the speed of the latest CPU control, providing for a very stable boost.
Separate power unit into the controller section in order to achieve a compact body
Water Proof Power Unit
89mm × 36.5mm, 11mm thickness flat-screen controller (except for the switch), you can paste directly into the instrument panel surface. In addition, you can change the direction of screen 180 °
"GAIN" boost adjustment helps promote wastegate compensation and keep constant boost.
Some Info
