Put some spec up on the turbo as I don't think some people will know what these turbos will run at.
Great turbo
Thx
Spec:
Brand: Trust GReddy
Product : Turbo charger
Model : T88H-34D
Power : 880ps
Max Speed : 100, 000rpm
Max temp : 900C
Max pressure ratio : 3.25
Max boost : 2.2kg/cm2
Compressor side trim : 53.82 In dia : 69.7 mm
Out dia : 95.0 mm
Turbine wheel trim : 72.35
Out dia : 85.0 mm
Ex dia : 72.3mm 5000rpm
: makes 400ps 5500rpm
: makes 650ps 6000rpm
: makes 775ps 6400rpm
: makes 850ps
The turbine holds over 850ps between 6800rpm to 8400rpm
Part Num. : 11500323 (22cm)
