I have just got my car back from Gary at GT-Art and all I can say is WOW !
THANKS GARY !
The car was suffering quite heavily from lack of throttle response at low revs. ie. below 4,000 RPM and the lag was unbearable .Now both cured !My turbos now seem to spool up from 2,500 revs (25/10's) which I find amazing. I also had a MAJOR problem with turbo shuffle,which has now been reduced significantly but can't be cured 100% unless one changes the manifold which is not cheap but on the agenda.Gary will soon be manufacturing his own manifolds which I'll probably will be putting on mine.I can't wait.
All the fluids in the car have been changed to Motul fluids apart from the gearbox which was supplied from the main dealer!The differance they have made is truly unbelievable !Especially the brake fluid which has made the brake pedal action just so much firmer !The car just seems to run that little bit better and more 'free' if you know what I mean with the Motul liquids in.
.Highly recommended if you want the best!
I can go on for hours talking about what Gary has done to my car (and many others) . All I'm going to say is you can't go wrong with him, which is also true with most of the Skyline specialists out there but in my books, GARY IS THE DADDY
when it comes to cars!He gives them loads of TLC which I have never seen before .
THANKS GARY !
