PARTS FOR SALE
R32
front and rear cross drilled special heat treated nismo spec large brake kit as used by Janspeed
includes brand new discs, calipers , bolts and pin retaining kit.
(Australian touring car)
2 selected front wheel bearings.
2 stub axle hub
front and rear light alloy hub castings
R33\34
standard turbos
standard fuel pumps
standard injectors
standard fuel rails
hks hard pipe kit intercooler
standard intercooler
selection of f-con v with harnesses
550,680,740 and 1000cc injectors
adjustable fuel regulators
fuel rails
fuel piping kits areoquip hose type
s\h exaust sytems
de cat pipes
large capacity\flow fuel pumps in tank
brake discs and calipers
steel head gaskets 1.2-2.0mm
std pistons s\h good
hks pistons
mmr pistons
GT-ART balanced and resized and new bolt conrods (exchange)
GT-ART balanced and polished cranks (exchange)
Trust sump kits (exchange)
nismo and standard bearing kits
GT-ART gas flowed (+ new hks valve guides) cylinder heads (exchange)
All HKS components
Nismo steering wheel bosses(twin and single air bag)
17 inch autech cross wire alloy wheels
17 inch tri spoke wheels damaged
3 inch 90 deg ss pipe bends
2.5-3 inch ss reducers
stainless mesh
Motul oils
Ceracote friction reducer
COMING SOON HIGH GRADE HIGH PRESSURE DRAG SPEC RACING GT-ART GEARBOX OIL
sequential shift lights
GT-ART balanced exhaust manifolds
GT-ART breather tanks
GT-ART short engines 1\2\3
Tarox brake kits
rbf 600 brake fluid
R32
2 stub axle hub
R33\34
standard turbos
standard fuel pumps
standard injectors
standard fuel rails
fuel rails
s\h exaust sytems
de cat pipes
hks pistons
mmr pistons
All HKS components
stainless mesh
Motul oils
Tarox brake kits
rbf 600 brake fluid
