379 bhp ATW is 449 bhp ATF mate. You do not have 130 bhp transmission losses.obviously that is Wheel bhp flywheel is 507.5
~550 bhp, go GTSS, more than that, 2530.i was considering these turbo's, i imagined they could comftably make 520 bhp. Seeing as im already running 444bhp i dont think these would be the right choice!?
i really want some decent torquey, quick spooling tubo's that will see me good for over 500 bhp comftably. Anyone have any ideas?
You can see it fluctuating between 1.3 and 1.22these turbos are capable of running up to 600bhp clarky, im only running 1.25bar of boost AS YOU CAN CLEARLY SEE IN THE GRAPH!
I am aware of that, hence why I corrected your miscalculations.THAT GRAPH IS WHEEL BHP AND BOOST PRESSURE!
Because a dyno operator calibrates it to show 507.5 that does not mean that it is true. Your transmission losses are not 130bhp. So far you have show that you are illiterate and naive.and vennuth this is the same dyno run with torque vs flywheel bhp so yes it is 507.5
I did not initiate a power debate, I simply pointed out that you do not suffer 130bhp transmission losses. You believe that you have 507bhp. Assuming that the ATW RR figure is accurate, you are wrong. ATW + 70bhp is a very solid estimate for ATF. I also am trying to help somebody, by telling him the facts.you corrected "my" miscalculations??. well i wasnt aware that i came up with those figures personally, the dyno dynamics RR came out with those figures so thats what they are, yes there may be fluctuations between different RR but thats what this one says the power is, i admit it is higher than the average tranny loss but as i said i did not come out with these figures myself, also the fact that 550cc injectors are running at 95% on this power backs up that it would be around 500bhp.
i am going to take it to another RR and compare the graphs, and im neither naive nor illiterate.
i only put this graph up to help people deciding on turbos, i was trying to be helpful, not get into a power debate. however you have just reminded me why i dont post much on here or try to help people as there is far too many idiots on here.
