1 - 13 of 13 Posts
GTC FRONT MOUNT INTERCOOLER KIT
The GTC universal bar and plate intercooler is constructed entirely of high quality 6061 aluminum and the core is 100% vacuum brazed. The polished aluminum end tanks are hand TIG welded for a perfect fit. The ambient fin pitch has been adjusted to provide an optimal fin density of 15 fins/inch. This gives the intercooler excellent flow properties as well as a large cooling surface area, and the efficient Bar & Plate core takes advantage of these properties.
The four threaded mounting points along the top and bottom of the intercooler make installation simple. Typical installations require little to no modifications to the vehicle.
Features & Specs
All TIG Welded 6061 Aluminum, polished end tanks
100% Vacuum Brazed Core
High Efficiency Bar & Plate Construction
3 popular Sizes available; Custom made size welcomed
Inlet/Outlet: 3inch
Max Recommended PSI: 40psi
Low pressure drop w/ only 0.2psi at 15psi of boost
Tested CFM: 1020 CFM
Fin Pitch: 15 Fins/Inch
GTC intercooler has 3" inlet and outlet and will flow enough air for approx 700hp, with a minimal pressure drop.
What is included in GTC complete intercooler kit?
- 1 x GT size Intercooler 600 * 300 * 76 mm ( Core Size ) / GTR size 610X300x100
- 1 x Complete chrome polish aluminium piping kit
- 1 x silicone hose connection kit
- 1 x stainless steel bolt clamp kit and mounting kit
- 1 x packing box
100% Aluminium construction
Fully polished side tanks
Tabs on bottom and top for easy installation
Improved 15 big bar design with offset fins to increase efficiency
GT Core size 600mmx300mmx77mm ( 23.7 inch x 11.77 inch x 3.1 inch)
GTR core size 610mmx300mmx100mm
End to end 780mm
Inlet 75mm (3 inch) O/D
Outlet 75mm (3 inch) O/D
KITS AVAILABLE FOR:
NISSAN SKYLINE R32 R33 GTS R34 GTT
NISSAN SKYLINE R33 R34 GTR
NISSAN SILVIA S14 S15
MITSUBISHI EVO 7 8 9
TOYOTA SUPRA
GTS £350 + vat
GTR £450 + vat
Hi Skykit, yes can do as long as your in and out let are same size. please contact the office. [email protected]
as fitted to Scott's new BNR34
any plans to make a r32gtr kit?
will the intercooler fit onto my HKS pipes [they fit on my standard intercooler]
Okay Ben, cheers anyway. :)
Hi scott.
I am sure my Hks kit I fitted to my 32 was from a 33/34.
There is very little difference really.
Can be made to fit but are a bit high by the rocker cover.
Easy fix with a hacksaw but I didn't bother as the bonnet shuts, :flame:
They are all rb 26 s so the main difference is the inner arches and air-box.
cokey
1 - 13 of 13 Posts
