Hi, am new here, have pulled an ECU code of 41 ???? Does anyone know what this code is.
Problem:
The car has NO boost (has negative vacume but stops dead at 0 Bar (atmospheric pressure) even under full load.
Turbos dont seem to spool !!!!
The engine runs perfectly with no hesitations or idle issues
ALL vacume lines have been checked and double checked
AFM's are fine
Fuel delivery is fine
NO leaks in any boost pipes from turbos through to the intake manifold
Actuators are fine and springs are fine
HELP :bawling:
Is there anything that would shut a GTR32 down in this way.... most cars i have dealt with always have some slight boost in limp mode.... I am lost on this one
Problem:
AFM's are fine
HELP :bawling:
