I need one of the above to go into my intake to make the car easier to map on my RB20.
Anyone got these?
I seem to remember its the same sensor as the water one,if that helps.
I've been down this route aswell and you will find that the sensor basicly reads the temperature of the manifold,not the air going through it, so due to the water coming out of the head through the intake on the rb's your biggest problem will be heat soak in the manifold.
I found if you get better results from putting a temporary thermocouple in the manifold without letting it touch the sides, hope this helps.
you need to put the intake temp sensor in the piping after intercooler before intake manifold, but not above the engine head, somewhere the piping comes in the engine bay.
and yes you can use a OEM temp sensor, settings are in the apexi for saying that you use OEM sensor.
i have a spare one if you need it
