1 - 14 of 14 Posts
Does anyone have or know where I can get a GTR hollinger center alignment tool for my hollinger centred clutch, or know of any other tools that will be suitable?
Cheers in advance.
bob
bl**dy hell that would be great if it does!!!!
bob
Hey buddy, not got round to refiiting the clutch yet, but shall post up the results if it works! Would indeed be a top tip if it does!
Cheers buddy.
bob
Official GTR.co.uk Photographer
sorry the late reply bob but been busy with the recent house move stuff.
the draper kit i showed you that i bought seems like an ok quality kit
the sizes as follows
--------small screw on end-------------big sliding cone end
--------lower lip - higher lip
size 1- 10.7mm - 12.6mm---------------15.5mm
size 2- 12.1mm - 15mm-----------------16.7mm
size 3- 13.4mm - 15mm-----------------19mm
size 4- 14.7mm - 16mm-----------------20mm
size 5- 15.7mm - 17mm-----------------21.4mm
size 6- 17mm - 19mm------------------23mm
size 7- 18.3mm - 20mm------------------23.8mm
size 8- 20mm - 22mm------------------26.5mm
tried looking on the net for the actual size for the the clutch's on an rb26 and couldnt find any thing helpfull
You could have a quick measure of your input shaft and get a local machinist to whip one up ....in ally or glass reinforced nylon etc:
(obviously doesnt need splines) just 2 diameters.
Discussion Starter #8
Ah bugger I think the holinger input is 28 mm buddy!
That does look like a tidy bit of kit though!
Well useful. Cheers for posting up the sizes mate.
Bob
Discussion Starter #9
Bloody he'll Glenn, that's a genius idea!
Nice one fella!
Bob
I presume you have a single center hub not 3 or 4 seperate clutch discs?
Discussion Starter #11
Hey Rob, it's a ATS Carbonetics one with a single centre hub and 2 carbon plates.
bob
but what happens if you have an os clutch with seperate plates, i can use the input shaft from my box before it gets built up but then i will be stuck if i need to take the clutch off.
Discussion Starter #14
1 - 14 of 14 Posts
