1 - 11 of 11 Posts
Guys,
Do you know the specific data for the OEM GTR front & rear wheels.
Front: 20 x X,X'' (width), Offset?
Rear: 20 x X,X'' (width), Offset?
Thanx
Guys,
Front: 20 x 9.5'' , Offset 45
Rear: 20 x 10.5'' , Offset 25(around iirc)
Thanx
hope that helps a bit,not sure on the rear offsets,but should be around that:chuckle:
Thanx!!
Thinking of buying some 18'' wheels for the track so I have to know the data :D
Thanx!!
+1
which wheels/tyre combos are you considering for track set-up?
Are you looking to match the total circumference per wheel to that of OEM Tyre/Wheel set-up?
Isn't that mandatory in order to avoid electronic troubles ?
Yes, I am looking to match the OEM diameter, the 18'' tyres would then be thicker than OEM 20''...
If the 18'' would be too thick, I will try to make it in 19''...
Now, it seems that there are not many wheels on the market that match the width of the OEM rim and the offset...
Do you guys have some reccommendations?
Buy a second set 20"....put some nice Toyo´s on and be happy....:chuckle:
Discussion Starter · #9 ·
20'' tyres would be too expensive to burn them on the track day...
19s would be much reasonable I think. But I'll see...maybe I'll go with the OEM wheels on the track, then just change the tyres...
The difference between 19" and 20" is not worth to speak about....20" Toyo´s are under 2000€ a set,they should last pretty good on track and take some punishment...:bowdown1:
Got my set today,need to put them on the Volk G2´s next week and then put them on the car...:chuckle:
Exactly my thoughts, figured that burning through 18" rubber would be that much cheaper; hence the wheels would pay for themselves after one year... perhaps I should check out some tyre prices
1 - 11 of 11 Posts
