quick question guys.
i know a GTR can send up to 50% of its power to the front wheels, but if u r doing 70 on the m/way, is it 100% rear wheel drive? or 90/10? etc, etc.
thanks
Administrator
should be 100% RWD, unless your rear tyres are bald/different size to the fronts, in which case you'll see the torque meter move slightly
mook
with decent tyres, in the dry and straight line barring drag starts, my gauge never moved.
in the wet (really ****ing down), you can see the gauge move at 70mph if you boot it a bit.
I have noticed mine starting to move all the time, even in the dry.
I think its down the wear on tyres being inconsistent
thanks
I do believe that the torque sent to the front wheels is measured in Kg's and not %.. meaning it can send up to 50 Kg's of torque to the fronts meaning no stock GTR can do that :p . The 37.5 kg's you have stock doesn't have enough power to send up front..
