My battery has basically died, it needs a kick most startups. I was running the original NS40ZL which comes as standard and uses the JIS posts.
Normal Overall Dimensions (mm)
Length:196
Width:128
Height:201
Total Height:220
Now I noticed there is a lot of room in the battery bay and i'm fairly confident this 70ah battery https://www.yuasa.co.uk/ybx3030.html
Length (mm) 260
Width (mm) 174
Height (mm) 225
It has a bigger length and width but maintains the same height along with the JIS posts. Has anyone done a larger battery mod with 70ah? Do you know a specific battery that is known to fit well at the larger 70ah size?
