1 - 9 of 9 Posts
Discussion Starter #4
I'm running 550bhp, would it be better to upgrade to different brakes all together or are the standard brakes good enough?
Discussion Starter #6
I got a set of pads/discs/lines/fluid for around £900, how much would a full set for r35 brakes and adaptors go for? plus what is the part you have to cut to fit the adaptors.
Has anybody else installed r35 brakes??
Will go for the r35 kit as well its the best you can get for the money atm. You are looking at 2000-2500gbp for a used set and then you need another 1500 approx for the brackets to be able to mount them on. Supertec's brackets are the best on the market atm.
May be selling my full R35 conversion kit if anyone is interested? Not decided on wether to use or not.
1 - 9 of 9 Posts
