Hi all
Can anyone recommend what disc & pads I should use for my R35 which is running just over 700hp.
Currently running below setup that will need changing soon, just wanted to know if these are good or should I change something more suitable for the power I’m running.
Oz
You could change the fronts to 390mm with the correct 5mm adapter, Alcons have plenty of discs out there without issues so I’d stick with those.
You’ll need to check wear on the bells.
Brake pad choice most likely comes down to what you use the car for, street, street and odd track day.
Ferrdo are ok or pagids if the budget allows.
