Car will be a Road car 90% of the time.
Have got S-tune suspension.
Would like advice on what ARB's to get & what type of Suspension arms & bushes, etc should i also upgrade to ? (specs, makes, pro's / con's)
Please bear in mind the car will be mainly for road use.
Obviously, goes without saying the car will get the geometry set up properly.
THX
Nismo. Having seen 3 Whiteline AR bars broken on MKIV Supras this year I have to consider their material choice is suspect. I also think Nismo bushes in the stock arms are a dood choice for a road car, albeit a PITA to fit. I assume from your post you are happy with the S Tune dampers, but if not Bilstein are excellent and cost effective gampers, or if the budget will stretch to something a bit more exotic Nitron do a range of Skyline dampers that work well.
