So - will somebody out there please tell me exactly what turbo I have under the hood!
I dont know if its a T28 or a T3 or what!
All I knwo is that they come with std ceramic hot wheel and a plastic/composite cold wheel.
If I need to replace it what would be a good std replacement with capabilitiy of running over 1 bar (without smashing itself to bits) and what is a good upgrade if chasing over 350 bhp?
Cheers again..
Jimmy,
If it is an early GTS, (1993/4) you'll find it will have steel wheels, and is OK for slightly more boost than the plastic / ceramic ones.
If your going for more than 350hp, you'll need to replace the injectors, amongst other things. :D
