Just need some advice on a turbo upgrade
My car is running all stage 1 mods through a richard bell mod ecu
If I upgrade the turbo, bigger and better is my car going to run better or worse because the map is done to a standard turbo or will the ecu calculator this in
If there is a custom map on the car I would think you would need a new map done to male the most of the new turbo
