Hi - do you have to take the rear discs off to adjust the handbrake ? noticed there is no adjustment at the cables so guessing there is an adjuster inside the disc
no just take wheel off pull rubber grommet out its at the top
A bit more tricky than that to be fair.
Can't rotate the 1 rear wheel to line up the rubber grommet very easily and tricky due to the drag from the Trans to determine what is dragging, Trans or shoe adjustment.
Satan
